CiaranMcKeown
After searching for a while trying to find out how to remove the bumper so that i could fit my new intercooler i discovered there was no real step-by-step guide as such available to show us how to do this.
Thanks to Television i got a "guide" and decided to make an easier version while i was taking my car to bits. Please edit and move if required .... here goes.
1. First, open the bonnet and locate the two bolts beside the headlights, they are 8mm bolts. Remove these and set to the side. Caution, there are little metal clips on the mount where these bolts fasten to, do not lose these as they easily slide off. They are a little piece of folded metal with two thruogh it just incase you see one lying on the ground because its popped off accidently.
