How to repair[resolder] a relay
grober
MB Master
Perth, Scotland
W204 ESTATE
Mate has a 219 and is suffering similar symptoms to an N10 relay fault.
Q. Are 129s fitted with N10 and where is it?
Ta.
If its an early six cylinder its going to be similar to a W124. I think its in the relay box behind the the main fuse box in the engine compartment. Take off the lid of the box held on by clips then remove 3/4 screws that hold on the fuse block and rear lid-you will need the bonnet all the way up for this It's in there I think? . http://www.mbclub.co.uk/forums/atta...7d1242462436-w124-ecu-problem-relaylayout.jpg
the convenience control module ITSELF is usually under the back seat [nearside] in the W124 Not sure about the R129 :dk:
Thanks. Good info
