I've replaced a component (which had capacitors as it was OEM audio crap from the 90s) with a co-ax in the past and I replaced the stock tweeters too.
It worked really well and gave me more clarity at the top end.
One can still knock off the bottom frequencies on a component if running larger woofers.
I've tried Focal previously and I found them to be very harsh midrange upwards so I would advise anyone to try before you buy if you can!
