How to replace the water pump E430 113 engine
lynall
Kent
The silver one.
Basically a doddle, remove fan, fan shroud, alt belt, all cooling pipes then unbolt and remove pump.
Ist pic yellow is the shape of the water pump quite a large jobby!
2nd pic is just engine block with pump removed.
3rd pic is of new pump of engine with all bolts sitting in the correct holes so they cant be muddled up, ie some are different lengths
