Television put an item on here on how to change an analogue tv to digital by using a Bush unit, no longer available, I picked one up on on eBay for a tenner, still trying to retrofit to CL, not easy as car was not specd with a tv originally.
I know have a tuner and the Bush unit but no harness to connect from tuner to comand
Still trying to resolve this though, project 42B!
Hope this helps, if you source the interconnecting cables can you pm me with supplier?
Thanks but it is the MB installed cables that run from the tuner to comand, as far as I can tell this is not fitted as standard and not included in the loom, if tv specd then additional harness is fed front to back to connect.
Might be a lost cause though if rear screen does not have tv aerial then it will be uneconomic to fit?
