Howard
MB Club Veteran
- Apr 23, 2004
- Location
- Toad Hall
- 2018 C63 Wagon / CLK430 / A150 / VW Pink Floyd Golf Cabriolet
Hi all
Need a bit of advice please , just had some new tyres put on the front of the little A class ( with brabus monoblock IV on it ) and they tell me that the centre bore of the wheels is bigger than the hub and that the wheel is not centring properly , basically the bolts are centring it , which is not good as the load is on the bolts.
I believe the hub is 66.6 mm ? But am struggling to find the centrebore spec of the brabus wheels , it has to be accurate to .1 of a mm apparently.
Does anyone know for sure what size it is ? I have found two sources in the US , one of which says 76mm and the other says 75.5 mm ?
Also , next question is , where to get them from ?
Many thanks in advance everyone !
H
H
