Hello to all
I got a problem , when I turn ignition on then turn the A/C on, the RPM playing between 5 and 10 (up down up down etc...) , but if i stoped the A/C the RPM will be normal ,
also , when I turn ignition on then turn the A/C on, the RPM playing between 5 and 10 (up down up down etc...) , Until the A/C external 2 Fans worked then the RPM will be normal !!!!
I removed the blug for Fan sensor , withen 1 menute the RPM returnd to play (5-10 up down up down) , then I returned the plug for fan sensor the RPM return Normal way
please any expert can help me
Note : my Car is C280 - 1996
Also i replace these parts (oil + filter -- gear oil + filter -- thermostat -- i checked all fuses --- Fuel filter --- 6 Bosch Spark Plugs)
there is no problem of high tempruter or huge fuel consuming or A/C cooling or no car smoke --- the car is perfect
Thnaks 4 all
Thnaks 4 all
