I know why garages charge so much - Pain
Discussion in 'General Discussion' started by crammy69, Oct 12, 2008.
  1. crammy69
    crammy69 Hardcore MB Enthusiast
    874
    Feb 12, 2008
    Sidcup,Kent
    Car:
    2001 W210 E55 AMG,2010 Fiat 500 1.2,2002 Triumph America,LML Star 125 DLX,1984 C70,2011 Thruxton
    Having followed Grober's example, I changed the charcoal filter yesterday in the 300CE.
    Whilst not a demanding job technically (else I could'nt do it :eek: ) I now can see why garages charge so much. The simple answer is pain. Your not paying for the expertise of the grease monkey with his shiny set of tools, no, you are paying so that you don't wake up the next day with numerous little cuts, scratches and back pain from bending and twisting into unnatural shapes to access tiny little pipes and screws.
    £75 an hour? sounds like a bargain.
    Cheers
    Simon
  2. Geryatrix
    Geryatrix New Member
    3
    May 31, 2008
    £75 an hour does sound a bargain, My local dealer charges over £100 per hour.
  3. bigstuff
    bigstuff Hardcore MB Enthusiast
    299
    Aug 24, 2008
    no pain no gain i did my auto box on my 300te with loads of pain but it was worth it
  4. Will
    Will MB Club Veteran
    11,307
    Jan 21, 2003
    Surrey
    Car:
    GL63 AMG / 190E 2.5-16 / Porsche 911
    The trick is to decide which jobs are worth DIY'ing, and which aren't.
    I personally aren't too keen on the really awkward jobs underneath - much easier for a mechanic with a proper lift to get access etc. Although to be honest, I'd probably attempt almost anything if I needed to.
    Some jobs that are fairly simple, but very labour-intensive can be the best route for DIY. £75/hour x 10/20 hours can add up to a very expensive repair bill.
    Will
  5. OP
    OP
    crammy69
    874
    Feb 12, 2008
    Sidcup,Kent
    Car:
    You are indeed right Will, and with a car that is becoming ever less economically viable, these little savings become ever more important. Mind you, the value in this particular job has been limited with the Mrs today claiming the smell of petrol remains!. Shame, as I'm aching like a trains hit me today.
    Anyway, onwards and upwards. Next job - take out the EZL unit and put some new heat sink compound under it.
  6. ms500
    ms500 Banned
    342
    Jun 18, 2008
    Too right it's a bargain, I certainly wouldn't want to attempt my head gasket, for which it's going in to be looked at tomorrow btw.
  7. OP
    OP
    crammy69
    874
    Feb 12, 2008
    Sidcup,Kent
    Car:
    Id be interested (scared) to know how much that would cost, as whilst poking around under mine I noticed the sump had a very liberal coating of oil - aah oil change, that should be next job.....
  8. ms500
    ms500 Banned
    342
    Jun 18, 2008
    I'll let you know, I'm gonna take it to a local indie and see what they say. I'm hoping to get it done within £500, but not holding my breath.
  9. Will
    11,307
    Jan 21, 2003
    Surrey
    Car:
    It's only nuts and bolts :)
    A head gasket replacement is a perfect example of a beneficial DIY solution.
    The majority of the cost is the labour. And most of the labour is fairly simple.
    Even if it took you two or three days (maybe one or two days over a weekend for example), it's several hundred quid saved - which could pay for something nice like a holiday :cool:
    That's how I look at things sometimes ;)
    Will
  10. Ade B
    Ade B Hardcore MB Enthusiast
    1,832
    Nov 26, 2006
    South London
    Car:
    2006 Accord Tourer iCDTI EX
    Oil change is easy, even I managed it :)
    Just make sure you have the correct filter housing removal tool - my motorbike is currently minus the correct one which seemed to fit but sheared following a bit violence.
    Olly removed it with the correct tool and a lot of force...
    Old cars are meant to weep fluids, shows character ;)
    Ade
  11. boeken
    boeken Hardcore MB Enthusiast
    449
    Feb 13, 2007
    Buckinghamshire
    Car:
    R129 SL500 from 96
    i think my wife would rather i take it down to the garage and spend the time with the family instead, that will probably change once i retire (in 30 odd years or so) and she will probably be very pleased to see the back of me for 2 or 3 days :D
Share This Page
