richard1975
- Nov 10, 2013
- s class
Hello,
this is my 1st post as I have only just joined so please forgive me if this has been done before.
I Have a solution to getting your I phone stored music into the command.
Cost is £25.00!!!
Buy a Bluetooth speaker attachment like you would for the home. e.g Bose 2 sound dock with a 3.5 plug in.
http://www.amazon.co.uk/dp/B00903LFMU/?tag=amazon0e9db-21
You then use this in the glove box connections with a 1x female to 2xmale splitter.
3.5mm Jack Socket To Twin Jack Plugs Cable - Speakers to Two PCs 0.5m: Amazon.co.uk: Computers & Accessories
The command then needs to be audio and change to aux.
PLEASE NOTE I DID NOT USE THE PRODUCTS IN THE LINK AS THERE IS LOTS OF CHOICE AND PRICES THE LINKS ARE FOR THE IDEA OF WHAT YOU NEED ONLY I DO NOT ENDORSE THE PRODUCTS.
Downside is you need to open the glove box and press the button on the Bluetooth box to connect you phone each time but its a cheap way to overcome the pairing problem without spending money on a phone cradle
(I am still working on how to overcome it and use the I phone for calls without the £240 cost)
Hope that's of help . If there is a cheaper way to do it let me know
Richard
Cost is £25.00!!!
Richard
