Thanks Alex, I suppose that is a valid point I hadn't considered. I expect high cruising on the Autobahns will pass enough cooler air through the H/E to maintain lower timing retardation?
I prefer to sort the cooling first myself whenever possible. When I stepped up a level when I had my old Cossie I fitted a larger intercooler before the larger turbo went on.
I'd like to track and drag my E55 at some point, but I don't want to be losing all the power at the same time. I'd like to fit a larger H/E but the oil cooler is in the way.
Larger intakes, in terms of the intakes into the throttle body? I guess it is quite difficult to change the intercooler on the standard supercharger?
Yep, bigger intake pipes help lower the IATs. On the standard supercharger, I would go with top mounted intercoolers like in SLR McLaren. This would not only allow for a larger surface area, getting the core out of the hot valley will help it run more efficiently too. Not a cheap mod unless you can do it yourself.
Yeah all very expensive and quite tricky to do. I have a standard TB but I do have an intake kit that I can re-fit to the car but the pipe work will remain the same size. I think other than given more s/c whine it is of little benefit lol.
With your build could you have relocated the intercooler?
