iCarsoft MB V2.0
OP
OP
W
wlpend
Wirral
CLK200 2005
Thanks AltonAnt, I will have a read through it. Just reading one part and it said the fibre optics are easily damaged if bent and I found one fibre cable bent in the boot, don’t know if that would be the issue or how to test it either! I have ordered a break out box for the OBD2 connection and will try putting a scope on it to check for interference on the CAN bus.
AltonAnt
2002 S203 C240
CANBUS uses a two wire system so the fibre should not affect it.
cws196
S205 C43 Estate
Yes, updated it as soon as it arrived, have tried both versions on the device. When I contacted iCarsoft they told me to try the version up to 2004, but no luck with that either!
Can you tell me which email address you used as I've been trying to contact iCarsoft and I get no reply at all!
E55BOF
South Bucks
CLS 350 SB, CLS 63 SB, SLK55, FJR1300,
From my experience, you'll get an answer eventually, but it can take a while...
