ICARSOFT MB V3.0 CAR DIAGNOSTIC MACHINE ( New Model ) PURCHASED FROM THE OFFICIAL RETAILER & ICARSOFT STOCKIST LJM CAR DIAGNOSTICS VERY LITTLE USE AS YOU CAN SEE IN THE PICTURES THE SCREEN STILL HAS THE PROTECTIVE COVER THE OBD CONNECTOR HAS A SMALL SPLIT IN THE CENTRE OF THE CONNECTOR PORT IT DOSE NOT AFFECT THE UNIT OR THE CONNECTION IM JUST MAKING YOU AWARE IVE ALSO ADDED A PICTURE IM SELLING IT FOR £130 WITH PAYMENT VIA BANK TRANSFER OR PAYPAL IF THE FEES ARE PAID I WILL SEND THE SYSTEM OUT VIA ROYAL MAIL NEXT DAY SPECIAL DELIVERY SIGNED FOR FEW DETAILS FROM THE WEBSITE The iCarsoft MB V3.0 has more advanced features and is the higher performance, upgraded version of the MB V2.0. It supports multi-system diagnostics, battery test, data review and printing. This scanner supports more powerful functions such as auto VIN identity, TPMS programming, actuation test / bi-directory Test, Fuel Pump activation, air filter self-learning, BCM (body stability), ECM (engine), TCM (tans adaption), seat calibration, Air Suspension Reset, ACS (Air Conditioner) adaptation reset, and head lamp calibration. iCarsoft MB V3.0 is a Professional and powerful vehicle fault diagnosis tool developed by iCarsoft Technology Inc. With a 4.0” TFT LCD and unique diagnostic software, it features full ECU diagnosis of single vehicle brand and test modes mainly include: CANBUS, ISO9141, KWP2000, and J1850 etc. It enables technicians to accurately diagnose complex problems. To ensure the device is compatible with your vehicle, please contact us or check the coverage list under documents. Please note that not all functions are supported on all vehicles. Suitable for Mercedes, the iCarsoft MB V3.0 is capable of performing the following functions: General diagnostics - reading and clearing DTCs Read live data Data review and print OIL = Oil Service Reset SAS = Steering Angle Sensor calibration EPB = Electronic Parking Brake system maintenance DPF = forced DPF regen (Diesel Particulate Filter Regeneration Control System) ETC = Electronic Throttle Control system BLD = Brake lock (ABS bleeding) INJ = Injectors coding BSC = sensor calibration and adjustments ECM = Engine Control Module / Unit IDL = internal stop/start systems (idle mode / vehicle idling) TCM = Transmission Control Module TPM = Tyre Pressure Management / Monitoring system ACS = Air Conditioning Systems SPS = air suspension calibrations AFS = Air Filter System maintenance FPP = Fuel Pump system Updates are free for life and can be downloaded via the official iCarsoft website. You will require a PC to update the tool. If this scanner is compatible with your vehicle, the multi-vehicle tools below will also support the same functions: |
