Icarsoft mbii - not connecting to a module
DavidL
s211 E55 , s203 C55
I wondered if my 211 e55 looked slightly uneven on the drive, it could just be the way it was parked. But I have acquired a mbii so I thought I'd have a play. But once in I found that, on the manual diagnostic, there is a suspension listing but I got an error code when trying to access it. I could access things that aren't there (like the heated steering wheel - no errors) and the parktronic that did have a couple of errors.
Is there an obvious reason it couldn't read it?
OneForTheRoad
uk.
2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
You could try with the engine on , or engine off 🤔
OP
OP
D
DavidL
s211 E55 , s203 C55
It seems to connect with the ignition on or off although I didn't try with the engine running. No harm in trying that. Thanks
OP
OP
D
DavidL
s211 E55 , s203 C55
sorted. Updated icarsoft software and re ran with the car running. No idea which made the difference but it did and all is well.
