Philip1972
Having sold the car, I no longer need this diagnostic machine.
Comes in proper case with cable and instructions. Even has the plasti cover on the screen!
Mb2
MB2.
Great bit of kit, and is in as new condition. £85 delivered.
Same as in the link here:
https://www.amazon.co.uk/dp/B07CTMR59C/?tag=amazon0e9db-21
Mb2
MB2.
- Oil Service, Brake Service (SBC Reset), DPF Reset (Diesel Particulate Filter Reset), Steering Angle Reset (SAS = Steering Angle Sensor), ETCS Reset (Electronic Throttle Control System)
- Reads and deletes all errors from almost all control parts. Not only OBD2, as OBD2 devices only relate to the motor control system. The iCarsoft MB II lists manufacturer-specific items!
- Engine control unit, SRS, Airbag, ABR, ESP, ABS, ETC, FTC, CDI, AAM, AHL, BAS, BCM, DAS, ESA, ESC, PTS, RFK, ICM etc.
- , B, C, CL, CLK, CLS, E, G, GL, GLK, M, ML, R, S, SL, SLK, SLS, SLR, Maybach
