Idling problems
Septypus
Mercedes diesel e class
I have an e-class 320 cdi and sometimes when the engine is idling it just cuts out. Does anybody else have similar problems ??
Air in fuel system (due to leak), or outer leak somewhere (most likely injectors), depends on which model year. Then pressure regulator is one culprit. CPS or injector plug. I assume car is not trying to 'escape' (gear on).
