If it wasn't for bad luck, I'd have none at all
ecossebev
Edinburgh
Mercedes Benz 230 TE
Driving home from work today, I got about a 1/4 mile away when I heard a bang from the rear. Not a loud bang, but loud enough to hear over the radio. A quick look in the door mirror, I saw a piece of 2x1 lying on the road. Assuming it was that I had ran over, continued and thought no more of it.
I pulled away from the lights 300 yds later and a metal against metal sound appeared, disappearing over 10mph. I could feel the brakes binding and could hear the rear discs rubbing against the pads.
Quick check of the rear suspesion, I could see nothing obvious wrong, however there is quite a bit of play in the o/s/r wheel with the handbrake off (up and down, side to side).
Is my diagnosis of a collapsed wheel bearing correct or am I looking at something else.
thanks in advance
Sean
I don't think it'll be the wheel bearing. But I don't think you should drive it till you've found out what's going on
Nick Froome
If you apply the handbrake is there any play. If not then as you suspect it will be a wheel bearing. If there is still play then check the wheel bolts are not loose.
