Ignition key shell
Stratman
Sunbury
W203 C200 CDI '04Estate
Are the outer shells available separately for my W203 Estate ignition key (2 button)? The buttons on mine are starting to disintegrate. It's the 2 button version of this
I could only find the 3 button ones (mine is a two) but they are the same and fit perfectly
There you go:
Two-button Key
I actually bought two - one just a case as above, and the other - full set with battery holder. Don't bother with the holder - OE one fits much better, and holds the blade, unlike the aftermarket one.
The shell is nearly perfect though :thumb:
Damn! I've already ordered a three button one :doh:
It looks like the PCB is universal (see the mounting points for the third button), so it won't be a problem as such ...
Unless you can ask your seller, if they have a 2-button ones, or if you can cancel?
I purchased a two button basic fob from an e bay seller about two years ago. Swop was easy and took just a few minutes, as a further point the three pointed star was protected by tape & still looks new.
There are Youtube videos showing methods of change over.
I'll stick with the three button one, if I become psychotically mad at it because of the extra button I'll get a two buttoner.
Thanks for the help one and all.
