Sphinx
Morning guys, I'm new to all of this and a complete novice with cars so you'll have to excuse me.
Basically through a turn of events, I've now come to own a 2002 Mercedes C200K Kompressor, Sports coupe. It's the 2.0 litre, manual.
Part of owning this car (and so cheaply) is due to a few issues with it, which I am to fix at a (hopefully) reasonable enough cost to justify buying it in the first place.
I have two main questions for now, and possibly more depending on how its usage goes, that I'm hoping one of you smarties here can help me with.
1) When starting and driving the car, my immobiliser light stays on. The car starts without an issue, it recognises the key etc. But the light itself just stays on, and I've no idea why this is. I always thought that this usually happened if the car wouldn't start.. Rookie assumption, clearly. I'd appreciate any help with that, as I'd prefer to know what the causes and remedies could be before entrusting a mechanic to flood me with jargon and "it could be this, that, this, or even that" repair costs.
2) When turning my electrics on (key position number 2), something makes a low whirring noise from the front-left of the dash, and it persists for a little while. I initially thought it was my heating system, so that was turned off. I then suspected my 6 CD changer in the glovebox, but removed the CD's and holder itself, and it still persisted. It's quite hard to explain the noise and its duration, so I'm sorry if this one was vague. It just sounds like something electronic is setting up, almost like the sound you'd hear if you held down the button on an electronic wingmirror.
Other than these two faults, the main one is already in the process of being fixed, which is a dodgy handbrake (or footbrake, in this model).
I appreciate in advance, any help, and will of course provide more information if I can on the issue. Thanks guys.
