Seriously though, the plate has to be work around £8 - 10K
I’d think any single digit number would be worth a bit , especially if your initials are SAE , or it means something to you .Seriously?
What's special about it other than the year?
Seriously?
You think they might be able to salvage both!!After restoration if you look carefully down in the engine compartment you will see both engine mounting bolts, these are original, everything else has been replaced
Just worked on the assumption that as 8 SAE is currently for sale for £10k then SAE 5 must be worth a similar price
