indicator problem
lukeo
i have a c220 sport n reg and i keep getting a problem with the indicators. the light for the rear heated screen will come on dim and thats it then, no indicators untill it finaly decides to go off. iv tried disconnecting the heater switch and they still wont work. any help would be grately apriciated!
If you mean the indicators don't work when the HRW is on (albeit that doesn't work properly either), then check the wiring to the fusebox.
It sounds as though the feed isn't sufficient to power both applications at once, probably due to a bad connection.
that is your relay mate. see my post. it is in your fusebox besides your abs relay.
http://www.mbclub.co.uk/forums/showthread.php?t=59447&highlight=2028204626.
If you can take the relay out, make sure the pins are not bent, clean them or just a little wobble might sort it out.
