Indicators Not working Properly
sweeney666
Bexleyheath,Kent
SLK230, subaru impreza
Hope someone out there can help. My indicators come on but do not flash. The same with the hazards. When I try the hazards the fuel guage goes wonkey. I guess it is the indictor relay as all of the bulbs are ok and they were working earloer today. Does anyone know where the indicator relay is? I have opened the fuse box, in the engine bay at the back on the drivers side, and taken the secondary cover off of that and I hav found a relay. The problem is this is not labled only the fuses.
I have seen a similar post but there were no actual answers only coments that this is an intermitent problem. I want to change the flasher relay and need to know if there is just a simple relay and where this is. :confused:
Help Please
Fuse box is a likely location for this relay, someone on here should be able to confirm the exact location.
I have just looked and its not in any of the boxes,,or in the boot, it could be under the center console, I will try and find it later.
Hope that some one else comes up with the answer
No idea about the SLK, I'm afraid, but a W124's indicator relay is on the back of the cluster. Don't know if that info helps or hinders...
Its called the multifunction relay. Does you roof work?
