paul73mt
- Jul 18, 2012
- Location
- Great Britain
- 2010 C350 CDI Sport sold , 2015 E250 CDI AMG Line Sold
We have a Neff induction hob yeah ok I did fit it in but if you pull the draw out your never gonna touch anything hot , none of out stuff in the draw has never got in the slightest warm. Mine wired I the cables is right at the back so no way of the cable getting damaged or touched
As you can see in the photos there's a gap but not a major one, But I expect every manufacture has there own specs. I have just looked at mine and their spec is
Metal objects stored inside the drawer could become very hot due to the air recirculating from the hob ventilation system. If this occurs, an intermediate support is recommended.
Intermediate support: A wooden panel can be used (figure 3) or you may order a suitable accessory from our Technical Assistance Service.
Worktop: Must have a minimum thickness of 20 mm. The distance between the top of the working surface and the top of the drawer must be 65mm.
So on mine measuring the gap between the top of the worktop to the tray is 88mm but from the bottom of the worktop to the top of the draw its 52mm, Now the bottom of the hob drops lower so really there only about 25/30mm from the draw to the lowest part of the Hob
