TKvS
Banned
I've seen a few posts regarding having your iPod / Smartphone connected to your car stereo / amp via Bluetooth, here's an inexpensive workaround that will give you basic access to the music on your chosen smartphone.
THIS SHOULD WORK ON ANY CAR THAT HAS AN AUX INPUT.
This will NOT provide :
1. Cover artwork on your screen.
2. Connectivity to your phone directory.
3. Steering wheel control.
It is ONLY an inexpensive method for playing .mp3 / flac / ogg music files via your car sound system...however it will route incoming calls via your Comand head unit..
It only costs about 30.00 quid ( minus phone / mp3 player).
What you need:
1. A smartphone, any smartphone that has a 3.5mm headphone outlet.
2. A 3.5mm male-to-male jack audio cord, choose your own length.
3. An Avantree Saturn BT transmitter / receiver.
STEP 1.
Connect the 3.5mm jack cable to the input socket on the rear of the Avantree Saturn.
STEP 2.
Connect the 3.5mm jack cable to the 3.5mm AUX socket in the glove box of your CLS.
STEP 3.
Connect the Avantree BT receiver to your smartphone ( do a BT scan to find it).
Once connected, choose where you want to put the Avantree receiver, I put mine in the glove box.
Select AUX from your Comand head unit.
Select a playlist and start listening, adjust volume levels on both phone and sound system accordingly.
N.B. the Avantree Saturn also has a micro USB socket if you want to connect it to ..say..your DC lighter socket to keep it constantly charged , plus it will also work as a BT Transmitter.
Not the most versatile solution, but means you can listen to all the music on your device.
AMAZON LINK TO AVANTREE SATURN
http://www.amazon.co.uk/dp/B0085HOM4K/?tag=amazon0e9db-21
What you need:
STEP 1.
STEP 2.
STEP 3.
