Hey! I'm new to the forum and have been following advice on other post but I'm still struggling massively.
I brought an ML270 last month, with the an injector bolt snapped, and the injector half ejected from the head. So I drilled out the bolt as far as I could, tapped a new thread etc etc.
So I have a M8x1.25mm bolt holding down the injector and I have replaced the copper washer, however this did not work and the injector was still leaking.
I heard about the injector seats where the copper washer sits not being clean and could possibly cause this, so I brought a seat cutting tool off ebay. I used the tool but did not apply much pressure as I didn't want to remove any metal if I could help it (and replaced washer too). However its still not sealing regardless of the pressure applied to the injector bolt.....
Any ideas?
Thanks Matt
Any ideas?
Thanks Matt
