Greenthing
Hello, I`m new to this site and have recently bought a 1995 e300 diesel estate, v.g.c. and only 115000 on the clock, I think!. It drove faultlessly on the 3 1/2hr journey home but could smell fresh diesel and found the return line from no.1 to the pump to be wet so changed all return lines. It soon filled up around the injectors with diesel again and after looking more closely this time I found that there is bubbling around the bottom of four injectors.
Is this common?
Where can I buy an injector removal/refitting socket from in this country?
I`ve been told there are copper washers which seal the injectors, might they just need pinching up or do they need removing, annealing and injectors checking?
There are a couple of other issues, the gearbox(4 apeed auto) when cold is slow to change through 1st 2nd and 3rd, it always takes about 3-5 seconds to engage reverse and when warm there`s an uncomfortable clunk/jolt when engaging drive. There seems to be plenty of clean oil on the dipstick. Also when warm, because the 1st and 2nd gears are so short, it revs high before changing and i can hear what sounds like a bit of cam noise for a few seconds.
Does all this sound normal for this car with a mileage of 115000?
Is there an alternative gearbox for it with better ratios?
I also have a 1998 c250 td and the ratios seem well spaced giving about 800 rpm less at 80mph.
Any help or advice will be much appreciated.
Is this common?
