Bigbossmonty
Hi Lads
futher to my other thread on Squealing you can see the problem after new propshaft fitted engine management light on.
So to investigate "No1 cylinder not performing" I want to check it f its getting any signals from ecu.
Is there a way to get to the injector wiring to test without taking of all the gubbings to reach the actual injector connector also anyone know the wiring set up of the socket?
I expect the body of the injector is the earth, one wire is inputing the signal and the other returns (Stop) to tell ecu its completed the fuel injection then it starts over again.
This is just my thinking of the way it works- on- off, on -off and so on
thanks in advance
BBM
thanks in advance
BBM
