No offence intended at all - but you need to understand your engine a little better before diving in
"Performance" injectors will flow more fuel - at the moment your car has no need for more fuel!!
Koolvins turbo conversion takes the power from 120Hp to 180Hp but it uses the same injectors as the std engine. Acoording to his A/F ratio gauge - he is running rich under boost - this means he doent need any injector improvements for his 50% power increase
If the engine sees more air - it injects more fuel its as simple as that . So firstly you need to get more air in - either by changing the supercharger pulleys ot getting a new supercharger.
You don't have to replace the injector if your compressor pressure has not been mod...
More air require more fuel, but more fuel also require more air!!!
If u want it to run efficienctly without mod, just stay with your injector..
Even some people replace the camshaft, they don't have to replace all of the injector, as the air flow meter will calculate how much fuel u njeed, and if the injector can't provide sufficient presure and fuel flow, they could just adjust the fuel pressure, to provide sufficient fuel rate for the engine, to have the correct A/F ratio...
If u really want to play with it, you could try to fit a fuel pressure regulator, to adjust the fuel pressure, to certain A/F ratio, for the engine to give Max power. The factory A/F ratio setting was always in the ratio of max fuel economy, but not max power. Mordern engine always run lean to have lower emission....
The stoichiometry A/F ratio (complete combustion) about 14.7 to 1, will give u max fuel economy, but not max power, emission and efficiency; for max power, it has to run a bit rich about 12 to 1, with the Garmma value about 0.85, instead of 1 (14.7 to 1)... If u want max thermal efficiency (lowerest emission), u need to adjust it abit lean, which is about 16:5 to 1.
To turn this, you have to use the rolling road turning or a lambra sensor, with A/F ratio meter....
If u feel interesting about this, I could send u the plot of power, efficiency vs air/fuel ratio by email or to the reply....
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
