Injexion 5
stuarth
Anybody ever used this for cleaning injectors? It is meant to go into the fuel tank but I am told these things can be used directly by filling up the fuel filter with it instead.
Anybody done this? (and done it with this specific product or are all the products doing this basically the same?)
thanks
grober
MB Master
Perth, Scotland
W204 ESTATE
Filling a fuel filter with it rather than adding it to a full tank of fuel is going result in a much higher peak /concentration of the material going through the system. This might be a good or bad thing depending on the problem you want to solve and /or the the reaction of the additive with any delicate parts of the injector system such as O ring seals etc. If you do use it I would adhere to the manufacturers recommendation as to how it should be used.
