I have three fault codes as follows:
1268 Charge pressure positioner - intermittent
126A Inlet port shutoff - intermittent
P200A Intake manifold air control actuator, bank 1 - performance problem. The description in my scan system says wiring, intake air control actuator, ECM
The car when I first set off is really noisy and revs high failing to get above 4th gear. After driving for a while if I stop and then restart the car say 30 minutes later it runs fine. I am hoping it's just the inlet port shutoff motor and not the turbo.
I am wondering of anyone on the forum has had these issues before and has a details description of whats involved in removing the inlet port shutoff motor and installing a new one. Any pictures or diagrams would be really helpful along with things like torque settings for bolts etc and how to test the original motor when removed.
Thank you,
Adrian
Thank you,
Adrian
