Hi All,
My shiny new e class arrived today
I have purchased the Alpine EZI DAB system and wanted some kind souls to guide me
Alpine - DAB - EZi-DAB
I have a few questions that I would really appreciate some help with:
1 - Where should I power the control unit from? It has the usual options, e.g. switched 12v, permanent 12v, ground, mute etc. Which options should be connected and where from?
2 - I was thinking to put the control box in the glove compartment top shelf, does that sound OK?
3 - Can I input to my audio50 non command head unit via aux-in at the back, as opposed to using the aux-in in the centre compartment via the UCI? If so, how?
4 - What is the best route to take from the glove box to the windscreen in terms of running the stick on amplified Alpine aerial? Will the merc windscreen block the signal?
Thanks to all in advance.....
James
James
