jamesshipway
- Oct 20, 2008
- E320 CDI Avantgarde (2003)
I currently have a W211 E320 CDI which has the the Audio 20 Cassette with the 6 CD multi change installed. I am interested in seeing what the upgrade options are to get a mercedes sat nav system installed. I've had a look on the forums here and searched the web but can't quite figure out what is compatible without a major installation. As I understand I could do the following:
- Install APS-50 by just swapping the head unit and installing and sat-nav aerial
- Install standard command - this would need a separate navigation unit in the boot (bit of a big job for me!)
- Install the latest command (NTG 2.5) where I would have to just swap the head unit and install the sat nav aerial
Am I correct in my assumptions? I am not that bothered about TMC but would like to know how difficult it is to install a sat-nav aerial and if any additional wiring is needed???
Thanks in advance for all of your advice and guidance.
