Spinal
- Sep 14, 2004
- Location
- between Uxbridge and the Alps
- x254, G350, Duster, S320, Mach1, 900ss and a few more
A (hopefully) nice HOWTO on installing Shudes nice pedals on my W202. Sorry to Iyse, but I couldn't resist typing this!
Items needed:
(Make sure you have all the necessary, BEFORE you start)
- 4 alloy pedals (accelerator, clutch, brake, and hand foot brake)
- Smallish Flat screwdriver
- W202 Mercedes
Optional items (recomended):
- Vacuum cleaner
- Mercedes spanner (as found in the W202 kit)
Step 1: Remove your matt, there should be no need to clean up yet (we all do clean under our carpets regularly, don't we?). Open your pedal packs (one or three packs, the ones with the brake, clutch, and hand brake). Observe the pedals, they fit over a metal "foot" like a realy tight rubber glove.
Put your hand behing the stock pedals, and pry them off, some force may be necessary. I recommend starting on a vertex, then putting the screw-driver under the gap and wedging the old rubber off. Repeat for the brake, clutch and hand/foot brake pedal.
Items needed:
- W202 Mercedes
- Vacuum cleaner
