tmehmet
I wonder if anybody has had the same problem I am having and can give some advise.
I have a W203 C200K and have a battery drain problem, if I dont use the car for a day or so the car doesnt start and needs to be jump started.
I bought a new 100ah battery TWICE so definately not the battery itself but something is drainging the battery overnight. I conducted a few tests to try and narrow down the problem. I done this by using an ameter on the battery and removing fuses one by one. It turned out that while the car was off the most amount of drainage was coming from the fuse for the instument cluster. I changed the fuse (knowing this wouldnt resolve, but for the sake of it) and I am still suffering the same drainage problem.
Can anybody help advise.
Many thanks in advance!!
