glojo
Hardcore MB Enthusiast
My son has the latest spec computer and is having problems.
He has listed the Intel Core2 Quad with four 1Gb strips of RAM.
This is what he has stated:
I have tested kits separately and cannot get either pair to run at full speed of 1600Mhz and also cannot run all 4 @ 1333Mhz
I can only run stable at 1066Mhz (less than my CPU's recommended bus bandwidth) and with 1.60V
Basically could you ask the people on your forum what do to when you have motherboard and DDR3 which is not running at it's rated spec (1600Mhz) or even reduced spec of 1333Mhz using all 4 slots on an X38chipset
I have
ASUS P5E3 (X38) with latest BIOS 0703
Intel Core2Qad QX9650 12MB cache 1333Mhz Bus (minimum DDR3 1333Mhz recommended) 45nm
4x1024MB Patriot 1600Mhz LLK rated @ 7-7-7-18 1.80V (2x2GB kits) all exactly the same batch
I have
