Billy-cls55
- Mar 22, 2013
Bosch pump
I had mine changed a while back via Mercedes bosch 10 is Merc part number 000 500 03 86, also either changing your pump or if you are having problems pump relay is the 1st step 002 542 83 19 about £7 and could save you a bit of money before condemning the pump.
With the Bosch 10 there is no advantage in fitting the CM30 pump, plenty of videos on you tube showing the same flow rate. Plus the Bosch unit it a direct fit. As Simon said you can get the bosch unit off ebay much cheaper.
