giusepppe
Hi, bought a interior blower and regulator for a company called "online carparts.co.uk", it then came all the way from Berlin. swapped the blower with the regulator and it never ran, do not know if it is the regulator at fault, going to test the motor tomorrow to see if it runs. whilst swapping the fan over I had to move the carpet out of the way, discovered it was full of water under the carpet, we had really heavy down pours yesterday, so I am wondering if the drains are blocked, causing it to flood through ventilating ducks, this is on the passenger side, so presume it will be the same on the driver side, just had the cabin filters changed, so I presumed they would check the drains, I am going to syphon out what i can tomorrow, I am assuming that could be the problem, but there might be another cause. Any solutions to the problems will be appreciated
