NormanB
No not the in care entertainment - the other stuff you know - like cold scrapy de stuff off - or you cannot see out of the windscreen! Except this is on the INSIDE!
Clearly, there must be moisture in the interior somewhere but a search has turned up nowt.
I went to the favourite place - drains under the bonnet and have cleared the two drains either side - awkward boogers they were from an access point of view (starboard one in particular) they were topped up with plenty of leaves and organis debris.
Seeking W210 advice and collective experience of other favoured drainage ports or anything else to check.
Thank you
Thank you
