Hi All
One of the reasons I joined this fine forum back in December when I got my w208 was to try and find a solution to a problem I had with my interior light and long distance alarm transmitting. I subsequently fixed the problem with some candair and fiddling but after 8 months it's come back.
The problem is and was with regards to the interior light cluster, when I open a door only the rear light comes on, the front cluster doesn't work at all. It also doesn't work for general use either and neither do the sun-visor lights. Along with this problem the long-range function of the remote stops working - it'll only work close up via IR.
If I prise the front interior light cluster out on the right hand side about an inch the cluster will suddenly start working perfectly and the long-range remote function comes back. Once I do this operation the int lights work perfectly, I can drive, go over bumps and the buttons stay illuminated and all buttons work as they should. I can then get out of the car, lock it via the long range remote, unlock it again and all works as it should. It's only when I leave the car for a undetermined length of time - anything over 5 mins it seems and the problem comes back. I am thinking a loose connection somewhere but am a bit confused as to why it only stops working once the car has been standing for a while..
Any ideas anyone?
Cheers
Andy
edit:
It seems this place is amazing! Just typing the question in sorts the problem out..
Having not bothered rectifying the problem from when it failed earlier this morning I just nipped down the shops and it had sorted itself out.. all the same would welcome any advice
Any ideas anyone?
Cheers
Andy
edit:
