AndrewHill
Hi all, my Mercedes A160 W168 has a light in the front on the roof (dome lights?), switch it on and two bulbs illuminate, there's also another light that's more like a spot light on the driver's side and in the back, there's two over the rear passenger doors and one in the middle at the back.
The spot light works. No other roof lights do. I'm wondering if anyone knows what could be the cause? I doubt all of the bulbs will be gone?
If it helps, the glove box light also doesn't work. Not sure if they're connected? But the spot light working throws me off... I'd assume that was connected to the circuit the other roof lights run off...
Link to image: Mercedes A160 W168 internal roof lights
I don't particularly want to pay out for new bulbs if they're not needed. I think the glove box bulb has had it as I can pull the metal end of the bulb off quite easily...
Sent from my G8141 using Tapatalk
