123ianmartin
- Apr 5, 2008
- C Class c240 sport est
I`m writing this hoping sombody can help as ive searched the posts to no avail. Ok here goes..... I have a problem with my 98 c class estate starting, the problem is slowly getting worse, when you turn the key the starter gives a quick turn and then stops, as it does this the rev counter jumps round to almost maximum. It does seem to make a difference if i press the accelerator in slightly. If when this problem appears i turn the key to start and keep the key in the start position around 3 seconds pass and it will try to start again E.G. turn the key, starter gives a quick turn and stops, 3 seconds pass and again the starter gives a quick turn and stops until eventually the car starts!!!!!!!
Any help on this would be great as i`m stuck??
As i said it does seem to make a difference if the accelerators moved slightly.
Also it is not the bladed key but the electronic one just in case that makes a difference.
Thanks.
Thanks.
