Internet problem
R2D2
C350
Does anyone know why aspx pages wont display and therefore why windows update wont open???
Cheers guys
BTW. I've got a new router....if that helps:confused:
I take it it all worked prior to getting a new router.
Who is your ISP and what make of router did you get.
Alex.
BT broadband and a belkin replacement router as the last one broke
I think that you may find that other web pages will be the same, like Hotmail, secured sites and sometimes Ebay too
Try changing the MTU (maximum transmission unit) size in thewireless router to a value of 1400. This setting can be found in most routers (I think?), usually under WAN settings.
I had a similar problem and changed the above and it worked after that, you may have to try different MTU settings though
Regards,
Alex.
I think It's under Connection Type, then hit the next button.
Enter the MTU value 1400 and then apply settings
My setting was 1432 when I changed it to1400 I lost all internet:)
Lost Internet?
Sorry about that, try this:
BT requires that you enter your BT username and password and these settings:
Encapsulation - PPP over ATM (PPPoA)
Multiplexing Method - VC-Based
Virtual Circuit - VPI=0 - VCI=38
Modulation - Multi mode
Authentication - CHAP
Failing that, I would call BT and ask them for proper settings
Here are their Numbers, call Free Phone Number first.
0800 1690199
0845 6007020
0870 2404650
Regards,
Alex.
Also a similar issue here.
Dr TCP is likely to diagnose & solve the active scripting issue (provided you have duplicated all the other settings from your old BT modem).
0800 1690199
0845 6007020
0870 2404650
Regards,
Alex.
THANKYOU!!! PPPoA Did it. Well done-thanks very much indeed!!
Well done,
No need to Thank me, just glad that you got it working.
Regards,
Alex.
