spock500
Need a bit of help here chaps (see link below for performance mod)
On the OM605 the pressure relief valve is shown as No 125 in the diagram which I suspected to be faulty but this may not be the case.
The old relief valve is shown below
The thing is there doesn't seem to be any difference between the old one and the new although I have only tested
them both by blowing through the bolt end and not actually fitting it.
Is there anything I can check for before fitting just in case its not faulty, the new valve was £42 so not cheap.
I noticed this difference looking down at the top - the new valve is on the left with a smaller inlet hole - do they wear through flow of fuel?
Are there any checks that can be done to determine if its working ok?
Original thread with details of the mod with spring operated valves;
http://www.mercedesshop.com/shopforum/showthread.php?t=234609&page=17
