corned
I'm waiting for the 'how to repair a broken fingernail' thread.
You know it's only a matter of time now...
Edit: Iron's too hot.
...and let's not forget an in depth discussion on the merits of 'big box powders'. I'm off now to catch up on the latest episode of loose women.I'm waiting for the 'how to repair a broken fingernail' thread.
Iron too hot.
Looking back at the original post, it shows a bottle of scented water.
Do you allways use that?
Try using plain tap water and see it its that which is causing the gunge.
The iron is too hot for the garments and bits of articifical fibre are melting onto the iron later to be deposited on other shirts. All garments have little labels which tell you what they are and the dial on the iron must be adjusted accordingly. Note that it is probably best to iron the cool setting stuff first as the iron will take time to cool down and not spoil the clothes which need the cool setting. Saves time. Frankly, for someone who gets their laundry down for them, you ought to be buying 100% natural fibre clothes anyway which cuts down on the problems. Silk still needs care though. I can't stand anything artificial. And when ironing particularly delicate stuff you do it through an ironing cloth so the iron does not contact the material but the steam or heat is let through. Just my 22c. Les.
PS I do all my own shirts and suits but undergarments do not require ironing in my opinion. Ironing while still a little damp is good too.
Just a quick thought, in between using it during ironing, do you stand it up on the board or rest it on the holder thing at the end of the ironing board?
My ironing board has an angled rest incorported into the iron stand, presumably to ensure that the steam jets are not blocked while it's standing.
Our forum's saddest hour?
One can always just have one's butler attend to these tiresome chores .
Under housekeeper. No self-respecting butler would do ironing of clothes, Mocas would be mad to try it.
I think Pontoneer meant the butler would instruct the laundry maid to carry out the offending task.
