Very true , when I did my 7g , I just used an oil transfer pump from eBay , about £7 ish , same type I use on the diff oil . A couple of plumbing parts to stop the oil running back , an adapter for the MB gearbox sump and it all worked a treat. Total cost £20 or lessOn top of Justin's parts list above, a low range torque wrench and a pump to push the new fluid in are required. This adds to the cost for DIYers.
The 12 V Aldi /Lidl pump works fine, I made my own tap for re-filling with a few parts picked up from the local hardware store, see attachment. The actual treaded insert pipe can be bought online, plenty of suppliers Try google "MB 722.9 Transmission oil fill pipe.". You will find pipes, pumps and many other Transmission related parts there.Very true , when I did my 7g , I just used an oil transfer pump from eBay , about £7 ish , same type I use on the diff oil . A couple of plumbing parts to stop the oil running back , an adapter for the MB gearbox sump and it all worked a treat. Total cost £20 or less
