Is Camber adjustable on W203's
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by kjay, Nov 27, 2008.
  1. kjay
    kjay Active Member
    998
    Aug 1, 2007
    buxton, derbyshire
    Car:
    C200k Coupe 2003
    Am looking to get a 4 wheel align and camber done on my 03 C-class coupe. The car is lowered with Eibach springs.
    Can the front and rear camber be adjusted or will I need to fit offset bolts, washers etc. If so where can I get them?
    Jay.
  2. x332race
    x332race MB Enthusiast
    1,107
    Dec 10, 2005
    I recently took my W203 to Wheels in Motion in Chesham.
    They adjusted the camber but needed different bolts....they had these in stock.
  3. partsspecialist
    partsspecialist Active Member
    411
    Jul 22, 2008
    Bolton/Manchester
    Car:
    Ford Focus TDCI
    Its funny bolts with a couple of grooves in them that go through the control arm bushes
  4. x332race
    1,107
    Dec 10, 2005
    They are not cheap either for a bolt!
  5. OP
    OP
    kjay
    kjay Active Member
    998
    Aug 1, 2007
    buxton, derbyshire
    Car:
    C200k Coupe 2003
    Thanks. Are these needed front and rear or just the rear?
  6. wheels-inmotion
    wheels-inmotion Active Member
    721
    May 18, 2008
    Hemel Hempstead
    Car:
    Daily hog is a Vectra
    Just for the front, the rear has OEM fitted adjusters.
    Most times the only need to install adjusters is to regain camber/ castor symmetry. The deeper camber positions are normally desired and this compliments the cars handling after lowering.
    A worry for the owner is elevated tyre wear but since the lowered car has less dynamic gains in the camber you can afford a lower figure.
  7. OP
    OP
    kjay
    kjay Active Member
    998
    Aug 1, 2007
    buxton, derbyshire
    Car:
    C200k Coupe 2003
  8. wheels-inmotion
    721
    May 18, 2008
    Hemel Hempstead
    Car:
  9. c240yaz
    c240yaz MB Enthusiast
    1,096
    Jun 21, 2007
    Was your insurance premium much higher with the suspension mod ?
    Reason I ask is mine goes through the roof if I suggest altering anything other than the wheels, which were an acceptable £25 additional charge.
  10. OP
    OP
    kjay
    kjay Active Member
    998
    Aug 1, 2007
    buxton, derbyshire
    Car:
    C200k Coupe 2003
    Re-newed this year with Adrian Flux.
    Listed every mod in detail. I think it was about 450 quid.
    They're also are quite good on price when it comes to engine mods.
    Jay.
  11. c240yaz
    1,096
    Jun 21, 2007
    Too much for me, I could not afford that, wife would kill me if I even suggested...:(
  12. OP
    OP
    kjay
    kjay Active Member
    998
    Aug 1, 2007
    buxton, derbyshire
    Car:
    C200k Coupe 2003
    450 was the full premium - Not 450 extra!
    Fully comp, Full NCB, 3 points, about 40 ish;) .
Share This Page
