MBLOVERMCR
Hi. I experienced a loss of power and the garage have said it’s my ‘charge air hose’ which needs replacing. They’re quoting almost £400.
I’ve found the part online for anywhere between £30 - £200. I’m willing to have a go at fitting it myself but I want to make sure I get the right part and that I’m not biting off more than I can chew or walk into any traps.
Is the charge air hose just the wide diameter pipe which runs vertical from the top of the engine bay down to the intercooler? I’ve seen things online that have me second guessing whether I have the right pipe - one of them makes it seem that it is a small diameter pipe which runs from the air intake to the turbo at the top of the engine bay. And if I check for damage myself should it be obvious or only evident when the engine is under load?
And there aren’t any sensors or fluids to be mindful of are there? I’ve attached a photo of what I think the part is that I should be getting. Hope it’s right - I’ll get a cheaper one if possible though.
Any help is appreciated. It feels like it’s pretty easy to make (easy) mistakes when you do things yourself. But I’d love to avoid forking out £400 if I can.
