Is it possible to use an iphone 5 with the mbu 1000?
MOR8A
Sussex
W212 E63 PPP AMG
Just changed phones and don't want to buy an mbu 3000 unless I have to. Info please.
Many thanks.
Many thanks.
Yes it is but depending on the age of the MBU1000 it might need a firmware update.
Could you tell me what setting (switch positions) I need the viseeo in? I assume that once that is done you just search for the device via Bluetooth on the iphone? If it does not see it then it needs a firmware update? If so how does one do that? Sorry for being a retard!
The switch settings should stay the same as you have them for your existing setup.
The manual for the MBU1000 details how to pair a phone to it.
If you need the firmware update you can order it here;
Firmware Upgrade for ViseeO | Bluetooth Adapter Updates | Firmware & Cradle Updates | Mercedes Retrofits | Comand Online Ltd
I thought that the switch positions were to do with the type on phone one uses? I thought that is what it said in the instructions anyway?
Correction to myself, the switches are for the cradle type. I have just tried it and it works. Many thanks.
