Sorry if I’m asking a silly question but how does snow foam soften sand?Where I live & work we get a lot of sand fall out, the SF works well in softening it off the surface- no it won’t then fall off with the foam, but it has loosened it and it’s visible. So for my situation it works, for others I get that it’s probably a step they don’t need.
For the record, I use the Bilt Hammer version and now a cheap small Karcher foam lance. I’ve had 2 x more expensive ones and despite flushing through etc they didn’t last a year each. The cheapo has worked for 2 years so far and I don’t even bother flushing it (not sure there’s any filter in there anyway!)
Is snow foam worth it?
Before I buy a lance to fit my pressure washer, is it really worth bothering with?
If it dries up too quickly it means you are doing it in very dry weather or direct sunlight
Sent from my H8116 using Tapatalk
If you are talking about the washing shampoo, I'd imagine it is not worth doing - however my machine (Karscher) has one of those built-in dispensers (for patio cleaner etc) and I am going to try using that.I presume its worth buying a foam adapter to apply shampoo?
Not impossible for 19C or less and away from direct sunshine in the UK. Try 7:30pm?So only use on overcast and high humidity days?
.........Try 7:30pm?
Yeah I had issues with foam as well, even when the car surface was warm or not mixing enough foam. I don't know about finesse, try and wash your car at Cyprus during summerDon't be silly that is G&T time.
I have a north facing driveway - my car (lives in the garage) is always cool and in the shade when I wash it and a couple of weeks ago, cool day (12 ish) , out of direct sun, the foam dried quicker than I could get the wheels done.
However there are self proclaimed experts that will tell me that Autofinesse foam is rubbish.
Sorry wrong word, loosen is what I meant!Sorry if I’m asking a silly question but how does snow foam soften sand?
I appreciate it may soften mud but then so does water?
Correct The more you write, the more it’s apparent that it is in fact user error
According to you!
However, I am man enough to take criticism and admit if am I wrong (not admitting that just yet). Looking at the AF Avalanche pages, my foam may be too thick (judging by their pictures). Will try with a more runny mix later this week...........
For me it's not about the cleaning it's the low pressure nozzle and the foam softening/lifting dirt and lubricating so the jet wash has a much lower chance of marring - than when it pushes dirt/grit around at high pressure on a dry body.Most people expect way too much cleaning ability from snow foam and thus end up being disappointed.
It does have its uses but for the majority a good pre rinse with a pressure washer is perfectly adequate.
cheers
Chris
