Littledigger
Is there a recommended procedure for cleaning the engine bay and engine?
it's a really really easy four step system
1. drive to your local tesco or asda or shopping centre.
2. find the group of eastern european men who clean cars for money.
3. pay money
4. sit back and relax.
For what reason?
Rule one :- Never, repeat never, use a pressure washer.
... Even dishwasher in spray bottle might do very nice job.
1) Cover up anything you think may cause a problem, i.e. connectors, airfilter inlets etc... Using foil or clingfilm, ensuring it's a tight fit.
2) Start with underside of the bonnet, spray degreaser or diluted all purpose cleaner and aggitate with a soft brush like the swissvax/envy style ones used by Detailers. Then rinse with water using a pressure washer or a hose on mist/spray. May need to do it in sections to avoid the cleaner drying before you rinse.
3) Spray degreaser or a strong mix of all purpose cleaner over the engine area, mainly engine cover, bonnet shuts, suspension mounts etc... Then aggitate with a soft brush. When it comes to rinsing using an open ended hose, use your thumb over the end to control the spray, you want it as misty as possible. Avoid spraying directly over the engine for more than a couple of seconds, rinse the bonnet shuts and suspension mounts then over the engine again for 2 or 3 more seconds. If using a pressure washer hold the tip of the lance 7-8 feet away from the engine ensuring only a light cloud of mist touches. If worried about water coming into contact with the engine, just doing the painted areas(suspension mounts etc..) around it can make a big difference.
4) Spray auto glym vinyl and rubber care over all the black pipes and any black plastic then close bonnet. Do not wipe or brush this stage, just spray and leave.
5) Wait a 10/15 minutes(crack on with the wheels, door shuts and a wash) then start the car and leave it to warm up to help it dry and ensuring it's running as it should.
6) Open bonnet to reveal a gleaming engine area.
You asked for a guide, I gave you one.
Should anything go wrong which is unlikely if done correctly then I'm not to blame. Also doing it by hand can make a big difference.
Before anyone says DO NOT do that. I do it for a living, done countless engines and never had a problem. I'd post some befores and afters of really grotty ones but it may not be welcome.
Adam
Because it's dirty and dusty?
Adam
Exactly , so you are a professional engine washer . I doubt the OP is one.
Personally i wouldn't let you ( pro or not ) wash under my bonnet , spraying water around but each to their own.
I think the same as Neil when i look at a car that is spotlessly clean under the hood - 'Where is the oil leak ?'
H
