conor1n
Hello everybody!
In January last year I got the MB bug with my S212 E350 CGI estate and bought an R230 SL500 back in September..
I have been able to justify the SL using the argument that as a DIY'er it will be a lot more affordable to maintain and I will only do a couple of thousand miles a year, max!
The E class was bought with 190k miles on the clock :wow and I have since put about 5k in 12 months (London!).. The price was significantly less than the other 2 or 3 350 CGIs that were available at the time so I was happy to punt. Love the car! It has been decent up to now. When I bought it I replaced the two rear air suspension bags with Aerosus units myself. Later in the year it was running lean due to a vacuum leak in some rubber hosing. Then when doing a lot of motorway miles back to Ireland for Christmas, it was burning an insane amount of oil. Turns out the 0W-30 was wayyy too light. So I switched it to 5W-40 and not burned a drop since.
Oh I nearly forgot....how could I!? The alternator gave up the other day, so that is currently on my sitting room floor waiting for a new voltage regulator, slip ring and brushes.
Overall i've been very happy and not spend much on it parts wise really. This summer I will do transmission fluid and rear axle.
How does that sound in terms of maintenance? Good/bad luck!?
The SL is decent.. I love the colour combination and just had to have it.. for what it is, with 78k miles I think I got a good deal. 10k miles ago it had a new ABC tandem pump fitted at a cost of about £1700.. which I think is good.
It has a bit of rust in the arches, and also a spot or two of paint chips which need a touch up. Leather vinyl in roof fold area has a little tear which needs repair. I will also do spark plugs, brake discs/pads all around. Have already serviced, with air + pollen + oil filter and oil change. I will also be doing a full flush/renew of the ABC fluid this summer too.
Cheers
Conor
Cheers
Conor
